Slide show settings |
You can change the slide show settings for each slide show individually.
In the main menu under "Slide Show"-"Slide show settings" you open the window with the slide show settings. You can also reach this dialog directly over the button .
Main Settings:
Here you can change the standard duration of your images as well as choose the random order for playback.
The display quality can be adjusted to your computer's power. The higher the quality the more power is necessary. This setting is of no consequence to computing videos. This is about the quality during playback in the AquaSoft ® SlideShow XP five & Studio-Player.
You can also set the aspect ratio here.
Slide Show End:
Here you can decide what is to happen at the end of a slide show.
Transitions:
You can choose here which transitions are to be used as arbitrary transitions. All transitions checked are included, all transitions crossed are not.
Music Settings:
The music settings are further explained here.
Background Music:
The subject background music is dealt with here.
Description:
This is the place to personalize your individual slide show.
Thumbnails:
Thumbnails are little preview pictures used in the storyboard and in the timeline. Here you can set their size and compression.
Logo:
If you want to start the show with a logo, you can choose an image file here. You can also forgo a logo completely.
Standard Player:
Replaying the slide show is done by the AquaSoft ® SlideShow XP five & Studio-Player. Here you can adjust its settings.
IntelliLoad specifies how many seconds of the show are to be loaded beforehand. For slide shows with long objects it may be useful to raise this number.
If you want to set your new settings as standard for every new show, click "As standard". Every new slide show automatically receives your settings. Through the button "Original settings" you can reset everything to factory settings. |
Copyright © AquaSoft ® 1999-2007 www.aquasoft.de |
