Common preparations |
Directories In order to achieve a good result quickly and effectively, you can make some minor preparations in advance. AquaSoft ® SlideShow saves an image list and, in that respect, keeps an eye on all directories specified. Image format AquaSoft ® SlideShow supports, inter alia, the following image formats.
As background sound the following file formats may be used:
Please note that MID and RMI files cannot be used when creating the video with the Video Wizard.
