Automatic and manual course mixed |
With AquaSoft ® SlideShow it is likewise possible to continue parts of the slideshow manually and let other parts play back automatically. You can alter this as you please. In the Toolbox you will find two Slideshow objects for this purpose:
These two objects make it possible to switch between continuing the show manually and letting it run automatically. By double-clicking or by drag-and-drop you can insert the objects into your show. If you, for example, insert the Pause object behind the 3rd image, the show will stop before the 4th image and wait for you to continue using the keyboard or mouse. The manual replay can be interrupted again with a Play object. For that purpose, insert the Play object at the point where the automatic course is desired. Artificial pause: You can also insert a Play object directly behind a Pause object. Thus, the show will be stopped at the image before the Pause object and, as soon as you continue, the show continues to run automatically. You can also use the Space bar to pause the show during replay. When you hit thr Space bar again the show continues.
