Movement paths with rotations
Home  Previous  Next
Movement paths with automatic rotations can be applied to the following Slideshow objects:
TBx_Image
TBx_Collage
TBx_Video
Images, Collages and Videos can now be rotated automatically directly at the movement path. This way it is possible to correctly rotate cars or planes according to the direction of their path.
Hint
This feature is only available in AquaSoft ® SlideShow Ultimate.
You can activate this option in the Object settings.
LA_Image_MovementPath_automatic_Rotation_i
Click the LABr_Menuicon and then Select all marks. You can see that the the car gets automatically rotated along the path.
