Using the SlideShow-Master
Home  Previous  Next
BspTut
The SlideShow-Master contains a series of slideshow templates which make it easy for you to create a slideshow.
At lightning speed you can select images and music to create an attractive slideshow in connection with a style.
Under File -> New -> Use SlideShow-Master you can access the SlideShow-Master.
Dlg_DSMaster1
Click Next to begin designing the slideshow.
In the next step please insert images using the Plus icon.
Dlg_DSMaster2
Then click Next.
Now insert your desired background music using the Plus icon.
Dlg_DSMaster3
Info
If you don't want to adjust the duration of the slideshow to that of the background music uncheck this option. With this option enabled the duration of the images will be adjusted to the duration of the music.
Next click Next.
Now select a style template.
Dlg_DSMaster4
With the Start preview button you can inspect the style template.
Bulb
With some templates you can enter a film title and further personal details. For that purpose, simply click the personalization data directly and enter your desired text.
Dlg_DSMaster5
Next click Next.
Now you can decide what the next step should be.
Dlg_DSMaster6
Edit slideshow:
Opens the style template with the images in AquaSoft ® SlideShow for editing. It is now possible to make individual adjustments.
PC DiaShow auf CD brennen:
This option opens the CD Wizard and you can record the show on a CD or prepare it for passing on. The CD recorded can then be reproduced on a PC (not on a DVD player).
Video auf VCD, SVCD oder DVD brennen:
This option opens the Video Wizard. With this the slideshow is recorded on a video CD or DVD. First the show must be converted into a video.
