Properties of Slideshow objects
Home  Previous  Next
As you have already learnt in the previous sections, there are so-called Object settings for the Slideshow objects. In these you can configure specific settings for the respective objects.
You will find the Slideshow objects in the Toolbox.
The Object settings can be shown fixed on the user interface (always embedded) or also only displayed when required. If you do not show them on the user interface, you can access the Object settings at any time by right-clicking the relevant object.
The following fundamental properties are available with every object:
Props_Common_ShowObject
Determines whether the object should be shown when playing back the slideshow.
Props_Common_Duration
Here you can set the exposure time. In other words, how long, for example, an image, text or video is supposed to be shown. The cross fading effects take place within this exposure time.
Props_Common_DefaultStay
In the Slideshow settings you can set a standard exposure time for your Slideshow objects. If you change the exposure time there, this applies to all Slideshow objects in the show in the case of which the standard exposure time was enabled and to  Slideshow objects which are newly inserted.
Props_Common_KeepAfterPlay
Normally an image or text is cross faded by a subsequent image. In that respect, the image lingers. If it is not desired in the case of a particular animation, the lingering can also be turned off.
Hint
If you deactivated an image of your show (Show object deactivated), it will not be displayed anymore in the Timeline. The Timeline displays only objects that are supposed to be replayed. If you want to reactivate an image you can do this in the Image list or in the Storyboard.
