View settings
Home  Previous  Next
In SlideShow you can choose from different pre-defined views on the main toolbar an under View. If you want to add other modules to the current view you can  select from the menu under View -> Controls.
Please have a look at our screencast to learn how to create your own favorite layout. The screencast is available at the following web address:
http://aquasoft.de/download/flash/edit_view_cast/ansicht_editieren.html
In AquaSoft ® SlideShow Ultimate you can save your layouts under View -> View management.
