First steps with AquaSoft ® SlideShow |
Start the program, then select an empty 4:3 slideshow in the Welcome dialog. Before you start with your work switch to View -> Layout. Here you will also find the Timeline. 1. Adding images
You can select and add photos via Add -> Images. You also can add whole directories via Add -> Directory. The selected images will be displayed in the Timeline. By using Edit -> Sort you can get the images into a certain logical order, e.g. by their EXIF-exposure date. Naturally, you can sort your images manually, as well. 2. Adding background music
Music enriches your life and your show. Via Add -> Background music you can select music titles by clicking the Plus-button. The order of the titles can be changed by moving them with the mouse. Remove titles from the list by clicking the Trash bin-button. If you select a title you can adjust its settings. Then click OK. The music titles will be displayed in the Timeline. 3. The show can begin
This quick you can see results. In two steps you added pictures and music, and now you can play your show. To do this click the Play-button in the menubar or F9. Transitions are selected randomly and each time you play the show your images have a different transition. That's not enough yet? You want to specify the display duration, enter text and define transitions yourself? No problem with AquaSoft ® SlideShow! 4. Image properties
Select the first image. On the right side you will find the image properties. Here you can assign a fixed transition, text and comments to the image. You can also customize the duration of the image.
5. Specifying transitions
If you don't want to leave the transition to chance select the one you want from the list. If you click the Adjust-button you can further edit the transition properties. With the
8. Ken Burns Effect
SlideShow provides predefined Movement paths in the Toolbox. Among them you can find the Ken Burns Effect. Drag the Ken Burns Effect from the Toolbox directly to an image in the Timeline. Now play that image. There are many more options to animate images with zooms and camera pans. You can find more information about this at a later point in this manual. 9. Image effects
Just as easy as adding a Ken Burns Effect you can assign other special Image effects. To do this go to Image effects in the Toolbox. Drag an image effect to an image in the Timeline. Click on this image and you will see it in Layout Designer with the effect applied. Image effects influence how an image is displayed. They are not transitions. Those you can find in the image properties (Box 4 on this page) and under Transitions in the Toolbox. 10. Creating a collage
In the Toolbox you can find the Collage-object. It allows the display of several images and texts at the same time. Simply drag it from the Toolbox to the Image list to insert it into the slideshow. Now select those images from the Image list that you wish to include into the collage and drag them to the Collage-object. Expand the collage so that the images are displayed. Under object settings for collages you can select the transition you want to apply. 11. Editing a collage
Select the first image in the collage and resize it in Layout Designer by using the position frame at the edges of the image. Now position the image. Repeat these steps with all images in the collage. In the Toolbox you can also find the Text -object. Select the last image in the collage, then click the Text -object to insert it. The text will be added as the last object of the collage. On the Text -tab in Object setting you can add and format text. Now position it. Select the collage from the Image list and click the ... from here -button to play the collage. 12. The powerful chapter
One image track is not enough for you? Then you can utilize the chapter. In contrast to the collage images and text inside a chapter don't lose their own animations and can also be temporally offset. Insert a Chapter -object and drag two images into the chapter. Open the chapter by clicking on the Plus -symbol, select the last image in the chapter and then double-click the Text -object in the Toolbox to add text after the image. To create a new track move the second image in the Timeline under the first. A red bar appears, which helps you with the positioning. Now move the Text underneath the second image and assign an animation to the Text -object via the Object settings. 13. Temporal fine tuning
Extend the duration of the first image to 10 seconds. To do this simply drag the right edge of the preview image farther to the right. Then move the second image to the right also using the mouse. Extend the text and move it inside the Timeline a few seconds to the right. Select the Chapter and click the ... from here -button. The text appears after the first image has been displayed for a few seconds and will be shown with an animation. In this example the text will also be shown in the second image. 14. Chapters can do even more
Chapters offer a variety of other options. Decrease the size of the second image inside the Layout Designer. In Object settings deactivate the function Fill. Now move the image a little inside the Timeline. Play the chapter again using ... from here. This way you can easily create many different picture-in-picture effects. 15. The chapter on a DVD? The chapter also serves to divide the show into different parts. It helps to keep the overview in large shows. In addition these chapters can be utilized in a DVD-menu later. (Feature of SlideShow-Manager, which is part of SlideShow Ultimate.) After you finished the creation of your show you can create a DVD for the DVD-player. This isn't necessary if you wish to continue to play the show on the PC. 16. Burning Under Wizards you can find the SlideShow-Manager. Here you can specify which menu to use to create your DVD. Select a template, then go to Project -> Burn project. The Video-DVD is for the DVD-player. A self-starting CD/DVD for PC will be created under PC show. If you're using SlideShow 7 Premium select Video Wizard to create a DVD for DVD-player. The CD/DVD and Archive Wizard creates a self-starting CD/DVD for PC. The conversion of a slideshow into a video can take some time. After that you can put the burned DVD in your DVD-player and start the show. Now you've created a slideshow with effects and background music. Your family and friends will be impressed. Naturally, there is much more to discover, and you can now start with experimenting with the multitude of other possibilities in AquaSoft ® SlideShow, like editing images, using zoom functionality, recording comments, burning CDs/DVDs, etc.
