Import Wizard |
With this wizard you can import your images from a scanner or from your digital camera, as long as these devices respond to the TWAIN32 interface. The images are saved and included in the Image list. They can either be improved with the editing function immediately or later. You can access these under Wizards -> Import Wizard.
Specify a Target directory in which the images should be saved. Selected the desired file format and, if necessary, adjust the Format options. If the images are supposed to be directly included in the Image list of the slideshow, enable this function. Then select the scanner or camera. Next click Next and then click Start. Your images are now imported.
