Integrated image editing
Home  Previous  Next
It is our goal to provide you with all necessary tools in one single program, the AquaSoft ® SlideShow. Therefore we integrated image editing functionality that allows you to enhance your photos for the slideshow. Of course there are specialized image editing applications that go far beyond the capabilities of the image editing module in AquaSoft ® SlideShow but it should be possible to solve the most important tasks inside the program.
Dlg_BitmapFX1
Use the right mouse button to click on the image and select the option Edit image. There are functions to crop and rotate images, for color correction, adjustment of brightness and contrast and some filters like blurring. By using the magnifying buttons (just like in Layout Designer) you can adjust the size of the display of the image or image segment.
Hint
None of the provided image editing functions modifies your original image.
The modification only affect the display of the images inside the slideshow.
