iPod Wizard |
To transfer the slideshow to your Apple iPod please follow the next steps. Connect the iPod to your PC Use the USB cable that came with your iPod to connect it with your computer. As soon as the message "Don't disconnect" appears the iPod is connected with your computer. In addition you need to install the software iTunes on your PC to be able to transfer the video. If you haven't done so already please download this free software from this Internet address http://www.apple.com/itunes/download/ . Start the iPod-Video-Wizard If you haven't done yet please open the slideshow you want to transfer with AquaSoft ® SlideShow. Then select the menu item Wizards -> iPod Wizard to open the dialog for the transfer to your iPod.
As long as the iPod is not correctly connected to your computer this state is displayed
On the first page of the wizard you have the option to choose between the default 4:3 or a user-defined resolution. Limit the size of the video if your iPod doesn't have enough memory available. The smaller the file size of the video the lower the video quality will be. Then click Next to reach the next page of the wizard. Specify the title of the video Provide a meaningful title for your video on the next page so that it can be found quickly. It will appear on the video list of your iPod after the transfer.
You're done Please wait while the slideshow for your iPod is being created. Depending on its size this process can take several minutes. Afterwards the video will be transferred to your iPod at once. Now present your slideshow - whenever, where ever.
