Manual control |
Should you wish to move on manually during the show, you can configure the SlideShow Player accordingly in the SlideShow settings. The SlideShow settings always refer to the current show open. From the menu bar you can open the SlideShow settings using the
Via the Basic settings you can access the Player configuration directly.
The Start paused option switches the show over to being continued manually. You can then continue the show using the cursor and scrolling keys. If you activate Forward/back per mouse click in the dialog, you can continue your show by clicking the mouse.
