Music settings
Home  Previous  Next
You can reach the music settings via Slideshow -> Settings -> Music settings.
Dlg_DSSettings_Music
The Music settings can be set as desired for each show. The standard settings are illustrated.
Dlg_DSSettings_Music_Activate
You decide here whether background music is supposed to be included in your slideshow or not.
Dlg_DSSettings_Music_RepeatPlaylist
In the Background music menu you can insert several tracks to provide background music for your show. Here you can decide whether this list should be repeated if all tracks have been played and the slideshow has not yet come to an end.
Btn_Playlist
Via this button you can access the Background music menu and can remove or insert tracks there.
Dlg_DSSettings_Music_DefaultVolume
Here you can set at what volume the tracks should be played back (100% = full volume).
Dlg_DSSettings_Music_FadeOutDuration
Here you can specify the length of the fading out.
Dlg_DSSettings_Music_FadeEnd
The background music can be gently faded out towards the end of the slideshow or simply broken off.
Dlg_DSSettings_Music_FadeOutVolume
If you use Sound objects or have recorded commentaries for your images in your show, it is expedient to fade out the background music when playing back these objects. Specify here to what volume the sound should be faded out.
0%        = Fade out completely
100%        = Do not fade
Dlg_DSSettings_Music_FadingDuration
Determines over what period of time the music should be faded.
Dlg_DSSettings_Music_AlsoFadeSounds
Here you can specify whether the background music should also be faded with included Sound objects.
Dlg_DSSettings_Music_Sync
If you use breaks and continue manually during the show, you can decide whether the music should also be interrupted during an image break, or whether it should continue. If a check mark is placed, the music stops during a break.
