Program settings
Home  Previous  Next
The Program settings refer to the basic settings of the program and not to the individual settings for your slideshow. For the slideshow created by you, the slideshow settings are decisive.
Under Extras -> Program settings you can access the program settings.
Plugins:
Dlg_ProgSettings_Plugins
Contains a list of all plug-ins additionally installed which have been installed by additional AquaSoft applications.
Add files:
Dlg_ProgSettings_NewFiles
Here you can determine how files are supposed to be inserted into a slideshow and how they should be arranged in this slideshow.
User interface:
Dlg_ProgSettings_GUI
Here you will find additional setting options for the user interface of AquaSoft ® SlideShow.
Temporary directory:
Dlg_ProgSettings_TempDir
AquaSoft ® SlideShow from time to time requires temporary disk space on the hard disk. Here you can specify in which directory temporary files may be buffered. A lot off memory is necessary during video cretion. If the Temp directory doesn't provide enough space you can specify another directory here.
Language:
Dlg_ProgSettings_Language
AquaSoft ® SlideShow supports several languages, which you can change here.
Automatic update:
Dlg_ProgSettings_AutoUpdate
Here you can set the intervals at which AquaSoft ® SlideShow is supposed to check for updates. This way you stay up to date So bleiben Sie immer auf dem aktuellsten Stand. Zur Prüfung wird eine Verbindung zum Internet benötigt.
Record sound:
Dlg_ProgSettings_SoundRecording
Using the Sound Wizard you can record spoken commentaries with your images by means of a microphone connected to your PC. Configure the recording settings here.
Sound system:
Dlg_ProgSettings_SoundSystem
The Sound system takes on the task of playing back the music included in the slideshow. Should you have irregularities when playing back the music, set the setting to Windows Multimedia here and then restart AquaSoft ® SlideShow.
CD/DVD writer:
Dlg_ProgSettings_Burner
Here the recognized CD/DVD writers are shown.
Confirmation:
Dlg_ProgSettings_ConfirmDialogs
Select the dialogs to be shown here.
Automatic saving:
Dlg_ProgSettings_AutoBackup
Here you can determine whether backup copies should automatically be generated while you are working on a slideshow. Under File -> Open -> Restore you can access an earlier status of your work.
Storyboard:
Dlg_ProgSettings_Storyboard
Configure your settings for the Storyboard.
Layout Designer:
Dlg_ProgSettings_LayoutDesigner
You can configure settings for the Layout Designer here.
Timeline:
Dlg_ProgSettings_Timeline
Configure the settings of the Timeline here.
Image list:
Dlg_ProgSettings_ImageList
Here you can select which information should be displayed in the Image list.
