PSP Wizard
Home  Previous  Next
To transfer the slideshow to your Playstation Portable please follow the next steps.
Connect the PSP to your PC
Use the USB cable that came with your PSP to connect it with your computer. In the menu of the PSP go to the Settings menu and select the entry USB connection using the arrow keys, and then hit press the X key of the PSP. As soon as USB mode is displayed the PSP is connected to your computer.
Start the PSP-Video-Wizard
If you haven't done yet please open the slideshow you want to transfer with AquaSoft ® SlideShow. Then select the menu item Wizards -> PSP Wizard to open the dialog for the transfer to your Playstation Portable.
Dlg_PSPWizard1
As long as the PSP is not correctly connected to your computer this state is displayed
Dlg_PSPWizard_NoPSP
On the first page of the wizard you have the option to choose from different resolutions. Since the display of the PSP has a 16:9 format you can choose this option to create screen-filling videos.  Limit the size of the video if your PSP doesn't have enough memory available. The smaller the file size of the video the lower the video quality will be.
Then click Next to reach the next page of the wizard.
Specify the title of the video and a preview image
Provide a meaningful title for your video on the next page so that it can be found quickly. It will appear, together with the preview image, on the video list of your Playstation Portable after the transfer.
Dlg_PSPWizard2
You're done
Please wait while the slideshow for your PSP is being created. Depending on its size this process can take several minutes. Afterwards the video will be transferred to your PSP at once. Now present your slideshow - whenever, where ever.
clip0012
Hint
If your PSP is not connected to your PC you can store the video file after its creation on your computer. So you can transfer the video yourself to your PSP at a later time.
