Text with movement paths
Home  Previous  Next
Just like images, you can also let text move along movement paths. Please read the chapter Simple movement shots first to get to know how to set movement marks.
Create a new slideshow TBr_New and insert a Text object.
TBx_Text
LA_Text_MovementPath1
Now use  LABr_AddMovementMark to add several new movement marks. Position them in Layout Designer.
LA_Text_MovementPath2
If you replay this small example you will see that the text moves along the path.
In the Object settings for Text exists an option to specify the behavior of the text along the path during replay.
Hint
This feature is only available in AquaSoft ® SlideShow Ultimate.
Props_Text_Textbehavior2_i
Text block
The text remains horizontally and moves along the path.
Separate characters
The characters are separately animated and snuggle up to the path.
Rotate text block
The whole text gets rotated along the path.
Rotate characters
The characters move separately along the path and snuggle up to it.
Example: Rotate characters
LA_Text_MovementPath3
