Adding videos |
You can not only use images in AquaSoft ® SlideShow, but you can also insert videos. In principle, all video formats which can be played back in Windows Media Player are supported. Should it not be possible to play back your video in Windows Media Player, the problem could be a missing DirectShow filter for the video format. This can partially be installed afterwards. There are different codec and filter packages available for download, e.g. the K-Lite Mega Codec Pack on Chip online. Please read the information to the codec pack and contact the author of the package if necessary. The installation of codecs can also affect other programs. To insert a video, you will find the the Video object in the Toolbox under Slideshow objects.
You can insert it with a double-click or drag the Video object with the mouse out of the Toolbox onto the Timeline or Storyboard or into the Image list.
In the Object settings of the video you now have various setting options. Should the Object settings not be shown in the view available to you, you can retrieve them by right-clicking the video on the Timeline or in the Image list.
Should the full length of the video not be played back, remove the check mark beside Play back the full length of the video. You can then determine the playback duration individually. You can crop the video at the beginning using Start time. If you don't want to play the video from the very beginning enter the point of time where you want the video to start. Under Duration specify its playing time. This way you select the part of the video to be played. Should the video not be intended to be played back full screen size, it can be freely positioned in the Layout Designer. You can also assign a cross fading effect to the video. The Fill background function enables you to see the previous image during playback of the video or cover it up with a colored background. Under Sound you can determine whether the background music is supposed to be faded out during the course of the video being played. Should you have your own audio or spoken commentaries in the video, you should use this function. Further Object settings of the video are explained here. The video can also be animated with a movement path. How that functions exactly you can find out here.
