Other formats |
With AquaSoft ® SlideShow XP five & Studio and AquaSoft ® DiaShow Studio you can convert your show even to additional video formats.
Herefore select in "Video Wizard" the option "Create Custom Video". In the next dialog you can select additional formats.
AVI video
AVI is a widespread video format and can be played from newer DVD-players.
Set the resolution of your choice and under "Compression" the codec you would like to use.
Please check at first which codec has to be used to create these AVI videos, so that your DVD-player can play them (operating manual). Then check if this codec is installed on your PC. If not you must install it, before you can continue. AquaSoft SlideShow XP five & Studio does not come with codecs.
WMV video
This format is only available in AquaSoft ® DiaShow Studio.
To create videos in WMV format a current version of Windows Media Players should be installed on your computer.
With WMV format you can use a very high resolution for your videos. The created video files can be played with Windows Media Player. Currently only a few DVD-players do support this format.
SWF video (Shock Wave Flash)
Videos created in this format can be embedded into your homepege. This allows you to present the created slide show with all included effects, texts and sound on the Internet. To display it in your web browser Adobe Flash Player must be installed on your computer.
This format is only offered if you have the full version of AquaSoft WebShow 4 installed. It will be released in the near future. |
| Copyright © AquaSoft ® 1999-2007 www.aquasoft.de |
