Full screen mode with different screen solution
Home  Back
In the standard player options the graphic mode for full screen playback can be set. When switching the screen solution Windows only accepts a fixed refresh rate or none at all. Because we cannot know your graphic card/screen combination, we refrained from setting a refresh rate. We did this to make sure your screen is not at risk. Windows switches automatically to a possible mode, which you can change (Control Panel / Display / Settings).
This warning is only important if you work with a changed full screen mode. The problem does not exist in window mode.
