From the menu bar you can open the “SlideShow settings” using theicon. Alternatively you can also open the dialog via “Slide show” -> “SlideShow settings”. Under “SlideShow end” you can enable the repeat function.
If you convert your show into a Video-DVD this functionality will be lost. If you create your Video-DVD with SlideShow-Manager you can there activate the repetition of the of replay.
