SlideShow-Manager |
The „SlideShow-Manager“ allows to burn multiple shows to a CD/DVD. It creates a CD/DVD menu that allows to navigate to a certain show. AquaSoft ® SlideShow Studio already contains „SlideShow-Manager“. If you're using SlideShow Deluxe and want to use „SlideShow-Manager“ you can purchase it as a separate product. You can find an extensive description of „SlideShow-Manager“ in the help files of „SlideShow-Manager“. A short description is included into this manual in chapter DVD-Player.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
