Inserting maps as images |
Navigate to the desired section of the map and click “Insert map section”. Earth Pilot now generates an image of the map, saves it and inserts it into the slide show. You can then exit Earth Pilot or insert further map sections. |
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
