Manual control |
Should you wish to move on manually during the show, you can configure the “SideShow Player” accordingly in the “SlideShow settings”. The “SlideShow settings” always refer to the current show open. From the menu bar you can open the “SlideShow settings” using the
Via the “Basic settings” you can access the “Player configuration” directly.
The “Start after a pause” option switches the show over to being continued manually. You can then continue the show using the cursor and scrolling keys. If you activate “By mouse click” in the dialog, you can continue your show by clicking the mouse.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
