Multiple texts |
In AquaSoft ® SlideShow there is also the possibility of fading in multiple texts either simultaneously or with a time delay. In the “Toolbox” there is the “text” object for this purpose.
Fading in multiple texts, in sequence In this example 3 texts to an image appear, in sequence. The number of possible texts is not limited. Insert an image. Using the “Toolbox”, now add 3 “Text” objects. You can do this with a double-click or by means of drag-and-drop (dragging with the mouse) into the “Image List” or onto the “Timeline”.
Now select the first “Text” object. In that respect, it does not matter whether you click it in the “Image List” or on the “Timeline”. In the “Object settings” of the “Text” object, you can now enter your desired text and carry out the formatting. Position the text in the “Layout Designer”.
Select an animation and then call the editing function of the text effect via “Edit”. So that the text is not faded out again before the next text is shown, the “No fade out” option must be set under “Fade out”.
You can also have the text faded out if it is no longer supposed to be visible when the subsequent text is displayed. Now repeat the steps with the second and third “Text” object.
Then play back the little show with In the “Object settings” of the “Text” objects you can change the holding time of the texts.
Showing multiple texts simultaneously In order to now not show the texts in sequence, but simultaneously, the “Chapter” object is required. Use the little show that you have just created.
Add the “Chapter” object into your show.
The “Chapter” can have several tracks and therefore show the “SlideShow objects” in parallel/simultaneously.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
