Particles |
The “Particle” object shows your images in a minimized form and moves them on the screen.
In the “Object settings” of the “Particle” object you can adapt the representation to your wishes.
The “Particle” object can in addition also be provided with movement paths. In AquaSoft ® SlideShow Studio you can even rotate the “Particle” object.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
