Full screen mode with different screen resolution |
You can modify the graphic mode for the full screen display in the player settings. When switching the screen resolution Windows can only assign a fixed or no frame rate at all. Since we can't know your graphics card/monitor combination we omitted the assignment of a fixed frame rate. This was done to prevent any danger for your monitor. Windows automatically switches to one of the possible modes, which you can change yourself. (see Control panel -> Display -> Settings) This hint is only of interest if you want to work with a modified full screen mode. The problem does not exist in window mode.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
