Creating a menu with chapters |
With SlideShow-Manager you can structure your menu using chapters. From AquaSoft ® SlideShow you already know that you can structure your slide shows with "Chapter" objects. SlideShow-Manager takes these "Chapter" objects into consideration and displays them in the project tree on the left side of SlideShow-Manager underneath the respective slide show. "Chapter" objects appear in the finished menu and can be utilized to directly jump from the menu to a certain position in the show.
Now you can fill the new chapter with contents by selecting one or more slide shows or chapters in the project tree and dragging them to the chapter. |
| Copyright © AquaSoft ® GmbH 1999-2014 www.aquasoft.net |
