"Nostalgia" image effect
Navigation:  Assign and create image effects
In this example you will learn how to use the Image editor to give the image a nostalgic effect.  Ultimate   Stages
Edit image
Edit image
1 Open image in Image editor
You have several options to open the image in the Image editor:
click the Brush icon located in the upper right corner of the image in Layout designer
or click on the Brush icon located in the Object settings window
or right-click on the image in the Timeline and choose Edit image
Dlg_BitmapFX_Effects
2 Add effects
After the Image editor has opened, select the Effects tab. Now add the Colorize and Histogram effects via the Plus icon.
Activate the Colorize option under Colorize and set a suitable color under Color.
Under Histogram, change the black point and the white point.
3 Save as image effect
Save image effect
Save image effect
You can save the image effect you have just created for future use. To do this, click on the Save icon and enter a name for the image effect. It will then appear in the Toolbox under Image effects / Custom image effects.
Left without image effect (original), right with image effect
