Functions in the Image editor
Navigation:  Assign and create image effects
1 Tools in the Image editor
Right-click the image and select the Edit image option. The Image editor opens. With the tools available here you can, e.g.
Rotate and crop images
Flip images
improve the image exposure
correct the color or colorize the image
symbol-hint
All image editing functions do not change your original image. The changes only affect the display of the image within the project.
Image editor
Image editor
2 Effects in the Image editor  VIDEO VISION   STAGES
In addition to the Tools tab, there is also the Effects tab. It is located in the center right corner.
With the help of the Plus icon you can apply effects to the image, for which you will find further setting options in the Object settings section.
Among other things you can
blur or sharpen the image
add a shadow
add transparency
add a border
Effects can also be nested and combined with each other, greatly increasing the possibilities for creating new image effects. From simple image enhancements to elaborate effects, you have many design options.
For further understanding of the effect editor, please also read the blog post "Wie ein Spiegelungseffekt entsteht".
3 Save image with effect
At the bottom left of the image editor you will find a button that will let you save your image with the applied effects as a PNG file on your computer.
