Template editor
Navigation:  Export a project > Menu Wizard
Template editor
Hint
In order to be able to create or edit templates, the developer mode must be turned on. You can activate this in Video Vision and STAGES via “extras / developer mode".
The template editor enables you to create your own templates and edit those that exist already.
You will find a number of tools to make your template. Add images, texts, buttons and project placeholders. On the right side of the editor window you can edit the properties of a selected object.
MenuWiz_Editor
Also observe the design guidelines for templates and the information on the types of templates in the Menu Wizard.
