More video formats
Navigation:
More video formats
Return to chapter overview
With AquaSoft <%PROGNAME_R%>PremiumandAquaSoft Video Visionyou can convert your project to other video formats.
In the Video Wizard, select the option user-defined video. In the dialog box, you can now select various formats via video format.
Dlg_VideoWizard5
AVI Video
AVI is a widely-used video format and is played by newer DVD/media players.
First check with which codec you need to create these AVI videos, so that your DVD player will play them (operating instructions). Then check if this codec is installed on your PC. If not, you need to install the codec. AquaSoft Vision does not include a codec.
Hint
Please note that an AVI video should be no larger than 2 GB. Most players will not play a larger AVI video.
Not every codec supports all resolutions.
WMV video
Hint
This feature is only available in AquaSoft Video Vision and STAGES.
To create a video in WMV format, you should have a current version of Windows Media Player.
The WMV format allows you to use a very high resolution for the video. The finished video can be played by Windows Media Player on a PC or via media players/Playstation on the television.
