Output 4K video
Navigation:  Export a project > Output as video
Output 4K video
 VIDEO VISION   STAGES  You can output videos in very high resolution, so-called 4K or UHD videos. The term 4K or UHD stands for a resolution of 3840 × 2160 pixels. You can choose this resolution as the template for your video in the Video Wizard.
Please note that for output as 4K video, your photos should not fall significantly below the resolution of 3840 × 2160 pixels. Especially when zooming in, a lower resolution would be noticeable.
1 Create 4K video with Video Wizard
Create 4K video
Create 4K video
Call  the Video Wizard from theWizards menu . Then click the Media file option.  Under Template for, you'll find several choices, including forPC or for TV and the resolution. Choose the option that suits you and the resolution "2160p".
If necessary, check the other export parameters under Information and adjust them via Advanced settings (see Output as video).
Under Target file, specify a location for the video or use the automatic location. Then click Create video.
2 Play 4K video
A video with 4K/UHD resolution requires a relatively large amount of processing power for creation and playback. Furthermore, you need a monitor, TV, or other playback medium that supports 4K.
