DVD/BR is not played anywhere
Navigation:
Return to chapter overview
The burning of your presentation to DVD or Blu-ray appears to have completed successfully, but the media is not playing anywhere.
Solution steps:
1.Update
Check via Help > Check for Update whether you are using the latest program version and perform an update if necessary. Then burn again.
2.Check your output path and proceed as described here:
Burn DVD
Burn Blu-ray
