Maps and animated paths
Navigation:
In the Toolbox under the objects tab, you will find the route animation field. There you will find a selection of various objects.
Simple path
Adds a simple path whose color and width can be changed.
The variant Simple path, evenly (with scale symbol) runs automatically with even time distribution. The second variant, on the other hand, works with individual time distribution.
Decorated path
Adds a path whose appearance can be greatly influenced. You can select vehicles that appear at the top.
The Decorated path, evenly (with scale symbol) variant runs automatically with even time distribution. The second variant, on the other hand, works with individual time distribution.
Map
Adds a map that is selected in the map wizard.
Map animation
Add a chapter, in whose first track you will find one of your selected maps. In the second track is a path that can be placed anywhere.
You can choose between a variant with equal time distribution for the path points (with scale symbol) or with individual time distribution.
Route animation in the toolbox
To use the respective object, drag it from the Toolbox into the Timeline. With the object mapand the map animation the map wizard opens following.
Bsp
In our video "Karten und Route animieren mit AquaSoft Diashow 9“ the route animation is presented in detail.
Info
The available maps are provided by OpenStreetMap. Depending on server load, loading the map material may be delayed or carried out incompletely. Then try again at a later time.
If information is missing in the map or there are errors, you can report them here: www.openstreetmap.org or correct them yourself.
