A brief overview
Navigation:  Export a project > Menu Wizard
A brief overview
To burn a DVD with a menu, you can use the Menu Wizard. With this you can burn several projects on one DVD.
1 Open Menu Wizard
Menu Wizard
Menu Wizard
Call up the Menu Wizard via Wizards / Menu Wizards. If you have just opened a project, it will be loaded into the Menu Wizard. You can add additional projects via the Plus icon, which is located on the left side under Menu. Under Template you can now select a design for the DVD menu. In the preview the menu appears, which already contains the thumbnails of your projects.
symbol-video
You can see the New template and Edit template options only in developer mode. How you can edit a template or create one yourself is shown in our video "AquaSoft DiaShow-Manager: Eigenes DVD-Menü erstellen".
2 DVD menu settings
Settings for DVD menu
In the DVD Menu tab you can set the aspect ratio with which the DVD menu will be displayed.
Under Video format, PAL is normally set for the European region. If you want the DVD to run on devices for the American region, set NTSC.
3 Burn DVD
Burning a video DVD with a menu
With the Export icon you call up the dialog for burning. Select the Video DVD there. With Burn project you create a video DVD. Click Next and Export project.
