Adjust templates settings
Navigation:  Smart templates
You can enter your own caption for each image, and text-only panels are also possible. For all this there are ready-made styles in the Smart templates, so the texts are not just inserted, but adapt to the style of the template. It may be that some people don't like the chosen fonts or would like some variety. All font styles can be customized, so you can override the template defaults with your own text settings.
Settings that are to be overwritten are checked here
After inserting the Smart template, select it by clicking on it in the Timeline. Now in the Properties you will see some options that may vary slightly from template to template.
