Keep ramdom values
Navigation:  Smart templates
Keep ramdom values
Each Smart template contains elements which are different at each playing and are randomly controlled. If, in this instance, you want to “keep” this random selection, so that this template can no longer be changed, you must first of all, in the Properties window, generate a new random value. To do this, click on the button New value.
Random value for Smart template
This code sets how particular objects, transitions and other effects within a specific Smart template are presented.
You can pass on this code to other users. If you use the same template, they will see the same settings as you.
