<< Click to Display Table of Contents >> Insert videos |
![]() Video object In AquaSoft Vision and Stages you can insert videos and edit them. Inserting videos into the Timeline can also be done by simply dragging and dropping them from the File browser of the Toolbox or from the Windows File Explorer |
After selecting your video, it can be viewed at Timeline. If you move the mouse pointer over the video, you can display a preview of the individual frames.
Under Extras / Program Settings / Timeline / Video Thumbnails you can find more settings for the number of preview images for videos and the preview under the mouse.
Video with thumbnails and single frame in the Timeline
Learn everything about the setting options of a video object in the Video chapter. To learn how to edit videos, see the Cut videos chapter. |
AquaSoft Vision and Stages can play most common video formats. Depending on availability and Program settings, the graphics hardware is used to decode the videos efficiently.
