<< Click to Display Table of Contents >> Project settings |
You can define the project settings individually for each of your projects. The settings you make here are always effective only for the active project.
Under Project / Settings you call up the window for the project settings. You can also access the settings directly via the slider button in the toolbar.
1 Main settings![]() Main settings in Video Vision
Presentation
Here you can specify the Default duration of your images, as well as choose a random playback order of the images. Decide whether to close or replay the presentation after it ends. You can also let the viewer decide what to do after the presentation ends. If you select Reinitialize current presentation and repeat, the show will be replayed, but random elements (e.g. random transitions, effects with random values) will be recalculated beforehand. This setting is relevant for the Monitor directory effect, for example. Control randomness STAGESWith AquaSoft Stages you can fix the sequence of random elements for the entire project. Random inserts, particles, or effects with random settings are played identically each time they are played. See also Control randomness |
For details on the project settings Music and sound and Background music, please refer to the corresponding chapter. |
4 Description VIDEO VISION STAGES You can personalize your project individually. Enter a title, author and description of your project here. The data is mainly informative, but can also be retrieved by the variables %titel%, %autor%, %beschreibung% and %copyright%. |
If you would like to start your presentation with your own Logo, you can select the appropriate image here. You can also choose not to use a logo at all. |
6 Project thumbnail VIDEO VISION STAGES An image can be stored here as a project thumbnail. This is displayed as an external project in the Timeline or can be embedded in the video when exporting certain formats, so that it is displayed instead of the first video frame on devices that support this feature. |
Depending on the selected Vertical aperture angle, the perspective distortion has a greater or lesser effect throughout the project. This optical distortion is noticeable in the 3D scene, in the 3D effects and also in 3D transitions. |
![]() Settings for Player in Video Vision and Stages |
The Live Player is responsible for playing the presentation . Here, you can configure its settings.
![]() Player-Menü (F1 während des Abspielens) Additional player settings for playback You can find additional settings for the playback monitor, the sound output device, hardware acceleration for videos, and much more in the program settings. You can also access these settings while playing a video in the player by pressing F1 or by clicking the gear icon in the lower-right corner of the navigation bar. |
Click the arrow in the lower-left corner once. In the menu that opens, you can choose whether to save the current settings as the default or reset them to the factory settings. |
