Manual input
Navigation:  Program overview
Manual input
Manual input helps you place objects in the Layout designer, resize objects, and time motion markers for animations, route animations, and camera pans/zooms. In the default view of  VIDEO VISION and  STAGES , it is located in the upper-right corner, in a tab next to Properties.
Open manual input  VIDEO VISION   STAGES
You can open the Manual input using the keyboard shortcut  Ctrl  +  M  or via the context menu (right-click) in the Layout designer. Double-clicking an object in the Layout designer also opens Manual input.
Manual input
Manual input
Path settings always apply to the entire path.
Time distribution: The time distribution of the markers along a path can be Individualized or Uniform.
With the "uniform" time distribution, there is only one start and end time, and any number of markers without time values in between. The path then progresses at a uniform speed. In the Layout Designer, the markers appear with hash symbols (#1, #2, #3, etc.).
Timing  STAGES : Path timing can be controlled using a curve. When set to “Linear”, playback proceeds at a completely uniform rate between the first and last markers. Using a curve, the path can play faster or slower and move forward or backward at defined times.
Active motion mark: Select the mark or the respective object to check or adjust the values.  Use  the + symbol to insert a marker after the active marker. Use the - symbol to delete the active marker.
The duration of a path can be specified using a time unit (time in seconds) or defined based on the object duration (percentage of the object duration). To change the unit, click  on the unit in the "Time Mark" and "Standstill time" fields and select % or s.
If the "Percentage of Object Duration"ption is selected, paths will scale accordingly when the object's duration is changed. In the Layout designer, the marks appear with percentage signs (e.g., 0%, 40%, 100%).
You can increase or decrease the current value of the active mark using the up and down arrow buttons, or by typing a value using the keyboard after clicking in the field.
Standstill time: Specify how long a mark with the selected value should be displayed.
With route animations, you can pause at a location before the route continues. When panning the camera, you can pause briefly on a specific part of the frame before continuing the pan.
Type of point: The "Soft" option is enabled by default. The change in direction along a path of motion is smooth; the movement begins and ends more slowly. If there are three soft marks, you'll see a curved line in the Layout designer.
For the "Hard" point type, changes in direction are abrupt, and movement proceeds at a constant speed. If there are three hard marks, you’ll see an angle in the Layout designer.
When you select "Bézier", you'll find additional handles at each mark that let you adjust the curvature of the smooth curve.
With the "Jump" point type, there is no movement between the marks.
To adjust the point type for multiple marks at once, right-click a mark in the Layout designer and select “Select all marks.” Once all marks are selected, right-click again and select "Curve type" and the desired type.
Size:  Specify the width and height of the object. Click the lock icon to change either the width or height; the other value will automatically adjust to maintain the same aspect ratio. Das Schloss kann mit einem erneuten Klick auf das Symbol wieder geöffnet werden und die Breite und Höhe unabhängig von einander eingestellt werden.
If both values are set to 100% (or 1000‰ or 1), the object frame will fill the entire screen.
The arrow icon allows you to reset the size to the default value of 100% for both width and height.
Size of the predecessor: If you enable this option, the size of the previous position frame will be used for a camera pan or motion path.
Click the drop-down arrow to open a menu that lets you copy a mark's size, position, rotation, or rotation center.
If a value from a tag has been copied to the clipboard this way, you can also apply it to a tag using the drop-down menu.
You can switch units in Manual input. To do so, click on the unit in the input field and select from the available options.
Position
The Layout designer works with a virtual resolution of 100x100 percent. Since the output is always variable, no fixed resolution is used here.
An image in the Layout designer is positioned exactly in the center at:
Percent: X=50% / Y=50% / Z=50%
Per mille: X=500 ‰ / Y=500 ‰ / Z=500 ‰
0 to 1: X=0.5 / Y=0.5 / Z=0.5
Clicking the arrow icon sets the object's position to the center.
Rotation
Enter the rotation angle for the respective axis here. You can enter the value directly using the keyboard or adjust it with the arrow keys. The angle can  be specified in degrees, revolutions, or percent. You can rotate an object "flat"—clockwise or counterclockwise—using the Z-axis.
Clicking the arrow icon displays the object without rotation.
Rotation center
If you want to rotate your object around the center point, enter the value Y=50% and Y=50%.
For example, to rotate the object about the lower left selection frame edge, select X=0% and Y=100%.
Edges
The value 0 means here that the edge is on the left or above. Counting is always to the right or down. This means that the edge at the value 100% is located at the very right or at the very bottom.
If a value above 100% is entered, the respective edge is located in the invisible area.
Relative input
If you activate the option, the values will always be applied relative to the currently existing position.
Depth sorting by means of the Z coordinate is effective only within a 3D scene. Outside of this, the depth sorting is only done by the sequence in the Timeline tracks.
