Video
Navigation:  Object properties
Video
Properties for Video object
In the Properties window for videos you can find the following setting options.
Name: Shows you the path and file name of your video. You can also swap the video for another video file using the folder icon.
Linksbündig
Rotates the video clockwise.
Zentrierter Text
Rotates the video counterclockwise.
LABBr_Proxy
 VIDEO VISION   STAGES  Calculate/remove proxy video(s)
Duration: Once you've changed the video's playback time, you can restore the original video length by clicking on the time.
Start time: Here you can specify the point in the video from which playback should begin. For example, if you don't want to see the first two seconds of the video, enter "2 s" in this field.
Deinterlacing: Choose from the options Automatic, Off, and Always. Enabling this option is only useful if you are inserting videos that were recorded using the interlaced method.
Speed: You can set it in AquaSoft Video Vision) and Stages) to set how fast or slow the video should play. Values below 100% slow down the playback speed; values above 100% speed up the playback speed.
Still image: If this box is checked, the video will be displayed as a still image for its entire duration. The frame from the set start time will be displayed.
Fade: A fade-in and fade-out can be assigned to the video. You can customize the fade settings using the "Adjust" option. The default settings are  configured in the standard object settings.
Fill:
- On = The background is filled with color if the video does not fill the entire screen. The background color can  be selectedunder "Fill color."
- Off = The background will not be filled, and the previous object will remain visible below the video. If you want to achieve a picture-in-picture effect, enable this option.
- Automatic = The program automatically sets the option to "On" for images/videos/Flexi-Collages in the first track. If you move an item to the second track or a lower track, the option is set to "Off." This allows you to create picture-in-picture effects more quickly. If you prefer a fixed value, you can set it yourself using the On and Off options.
Aspect ratio:
The aspect ratio describes the relationship between the height and width of the video. If a video deviates from the aspect ratio of the project, you can decide here how the video should be displayed.
- Keep: The video gets borders while playing.
- Crop: From the edge of the video, parts are "trimmed" until the video fits the correct aspect ratio, without creating borders.
- Stretch: The video is inserted into the aspect ratio of the project, distorting the image.
- Center faces: Faces are taken into account when cropping (face detection) and, if possible, are centered and not cropped.
Alignment: defines where the video should be positioned on the screen.
Rotate in motion direction: If you have assigned a Motion path to the video, you can have the video automatically rotate along the path.
symbol-video
How to cut, speed up or slow down videos, see our video "AquaSoft DiaShow 10: Videoschnitt, Zeitlupe und Zeitraffer".
(Link address: aquasoft.de/go/nky3)
Sound (Video sound)
Sound of the video
Sound of the video
Here you can specify whether the background music should be faded while the video is playing.
If the video has no sound of its own, but may have recorded noise, set the volume of the video to 0% and uncheck Fade background music. This way, existing background music will play while the video is running without lowering the volume.
If the checkmark is set at Fade background music, existing background music will be faded (turned down) according to the music and sound settings while the video is running.
Clicking the Maximize volume button raises the volume for the complete video sound of the object so that the loudest part corresponds to 100%.
For Fade in video sound and Fade out video sound, enter the duration for which the video sound is to be slowly faded in or faded out. Activate/deactivate the function with the check mark.
In AquaSoft Stages, the volume can also be edited directly in the Keyframe track of the video.
Text (video captions)
Caption of the video
If text is to be displayed while the video is playing, it is stored here.
 VIDEO VISION   STAGES  You can use the track selection to store various text information on a video object. This can be, for example, labels in different languages or an automatic transcription. The track name is used for orientation.
Linksbündig
Edit track names
Zentrierter Text
New track / Transcribe new track automatically / Load new track from file...
Bin
Remove track
Only one text track can be displayed when playing the video object.
If a text is inserted in the text field, it is displayed for the entire duration of the object. If you do not want this, you can work with Text timing or alternatively Label the video with a text object.
The detailed setting options for text design can be found in the Text object properties chapter.
Opacity
Changing the Opacity is described in the chapter "Animated transparency".
