PC-Show |
Your slide show can also be played back on a different PC, on which AquaSoft ® SlideShow is not installed. The CD/Archiving Assistant will assist you in burning your slide shows with all the data to a CD/DVD or archiving them on the hard disk. Under “Wizards” you can open the “CD/DVD and Archive Wizard”.
After selecting the task, click “Next”. Creating and burning a slide show CD:
Specify a “title” for the CD/DVD. This title is used as the name of the CD/DVD. Should you use fonts in the case of which you are not sure that they are installed on other PCs, you can also burn them onto the CD/DVD. Archiving the slide show, preparing the CD or passing on the slide show This option enables you to save all data (ads file, images, music) in a common directory. This option is also very well suited to archival storage. In this way the slide show can also be saved on external data carriers (hard disks, USB sticks …).
In order to save disk space, you can pack all the data into a ZIP archive. Should you use fonts in the case of which you are not sure that they are installed on other PCs, you can copy these as well.
"Protect images from being accessed": Should you wish to pass on the slide show, however not permit access to your images, you can have your images protected. This function is not suitable for archiving, since this show can no longer be edited. It can only be played back. It is no longer possible to restore the images. You should not delete your original images from the hard disk. You should copy the “Slide show player” in order to be able to play back the show on computers on which AquaSoft ® SlideShow is not installed. Without this player you cannot otherwise play back the show. Click “Next” and then click “Start”. Now all necessary data for the show will be copied into the folder specified or combined into a ZIP archive.
| Copyright © AquaSoft ® 1999-2009 www.dvd-photoshow.com |
