After you created a menu you can create a CD image that you can burn to CDs later.
CDs created with this image can then be replayed on any PC.
| 1. | Load or create a new SlideShow-Manager menu.
Click on the entry "Project" in the project tree on the left side of the SlideShow-Manager window.
| 2. | Click on the tab "PC menu". Here you define the settings for the export.
| 3. | In the area "Window" select one of the pre-defines resolutions or type in the width and height of your choice.
The finished menu will later be replayed in the resolution you defined here.
Activate "Show button hints" if you wish to see hints about the functionality of a button later when moving over it with the mouse.
| 4. | Click the button.
| 5. | Select the output format "PC menu" and click the "Next" button.
| 6. | Deactivate the check box "Burn project" and activate the check box left of the drop-down list.
Select the entry "Create CD image (ISO)" from the drop-down list.
Specify a target file and click "Next".
SlideShow-Manager will warn you if the ISO file you specified already exists.
| 7. | SlideShow-Manager is now ready for the export. Click the "Export project" button.
| 8. | Click "OK" after the export has been completed.
