Playing a menu in SlideShow-Manager
Home  Previous  Next
While you're designing your menu you might want to see from time to time how your menu will later look like.
To do that click the TBr_Play button.
Provided you have at least one show or chapter in your project the menu will now be replayed. Use the mouse to navigate in the menu via buttons and slide show objects.
Menü
To stop the menu press the "ESC" key or click the little x in the upper right corner of the menu window.
Copyright © AquaSoft ® GmbH 1999-2014 www.aquasoft.net
