Creating and editing a template
Home  Previous  Next
SlideShow-Manager allows you to become creative yourself and design own templates  for your menus. To do this use the integrated Template Editor.
1.To create a new template click on the "New template" button in the template catalog.
To edit an existing template select the template you want to edit and click the "Edit template" button.
Vorlage bearbeiten
2.Design the template with the help of the editor.
3.Save the template by clicking the TBr_Disk button. You will be asked to specify a file name if you've created a new template or have edited one of the templates  that came with the product.
Type a name and click "OK". Your template will then be saved as project template.
You can also save your template directly as project or user template by clicking on the arrow right of the TBr_Disk button and selecting the saving option of  your choice:
Speichern als
Copyright © AquaSoft ® GmbH 1999-2014 www.aquasoft.net
