Save custom image effect
Navigation:  Save custom settings
Create or adjust image effect
1 Create image effect
You can create extensive image effects in the Image editor. Of course, these can also be saved for use in later projects.
After you have created an effect in the Image editor, click the disk icon to save it under its own name.
Enter name for image effect
2 Enter title
A dialog for saving the image effect opens. Enter a suitable title here.
3 Image effect in the Toolbox
You can now find your image effect in the Toolbox under Image effects / Custom image effects under the name you entered in step 2.
