Output image list as text file
Navigation:  Export a project
File - Save as
File - Save as
You can have the objects you used in your project listed in an image list.
To do this, go to File / Save as.
Save as text file
Save as text file
Under File type,select theText file format (tab-separated).
The image list is then output as a file with the extension .txt. This can also be opened in Excel for a better column view.
The list contains the following information about the objects used in the project: position, duration, file name, caption, font, keywords.
You add keywords by selecting an object in the Timeline and calling up Workspace / Panels / Keywords in the menu bar and leaving information in the window that opens.
