Intelligent templates
Navigation:
Intelligent templates are ready-made projects that you just fill with your photos, videos and music. You can add image captions as well as insert text objects that will appear in the show as a text panel.
Use Intelligent Templates
Insert Intelligent template
Insert Intelligent template from Toolbox
To insert an Intelligent template into a project, drag the desired template from the Toolbox to the Timeline.
In the next step, select the images to be inserted with the template.
Personalize template
After that, depending on the selected template, you can enter titles, subtitles and other information that will be used for opening and closing credits. After you have confirmed with OK, you will see the Insert Intelligent template together with the images in the Timeline.
Alternatively, you can use templates with the Intelligent Template Wizard.
