Menu Wizard
Navigation:  Export a project
Menu Wizard
 Ultimate   Stages
With the Menu Wizard you can create DVD and PC menus from your projects using templates. You can it combine multiple projects and burn to a DVD.
Use one of the included templates or design your own templates for your menus with the built-in Editor.
You can also use the Effects system to design your templates.
Provide your templates with an introductory title page and a concluding end page and underscore the whole thing with music.
The menu wizard takes into account the structure of your projects and at the same time allows you to create your own chapter structures.
View your projects directly on the PC or burn them to CD or DVD and play them on another PC.
Create DVDs in 4:3 or 16:9 format, which they can play in any DVD-Player or on the PC.
