DVD-Player
Navigation:  Export a project
DVD-Player
Video-Assistent für DVD
If you want to create a DVD for the DVD-Player, the Video Wizard will help you. It creates a video for you from your project and then burns it to a DVD. Ifyou want a DVD with a selection menu, use the Menu Wizard. You can also use it to burn several projects onto one DVD.
1 Burn DVD
First call up the Video Wizard via the Wizards menu. Under Burn you will find the option to burn a DVD that can be played back on the DVD-Player.
DVD
Creates an MPEG2 video and burns it to a DVD as a video DVD. (Resolution: 720×576)
Select the DVD option if you have a DVD burner. After the selection, click Next.
Erweiterte Einstellungen
Erweiterte Einstellungen für DVD
Everything that is important for the DVD has already been set for you by the Video Wizard. Nevertheless, you can make advanced settings here.
PAL / NTSC
If you are creating a DVD for a European device, select PAL. If you want to create the DVD for the USA, select NTSC.
Burner
Under change... you can select another burner and reduce the burning speed.
Bitrate
The higher the bit rate, the more information is stored, thus the file becomes larger.
If "constant" is selected, burning is done with a constant instead of a variable bitrate.
Smoother video through interlacing
With interlacing, two temporally offset fields are stored in the video. This means that movements are displayed twice as smoothly, but the resolution is reduced and edge flicker can occur depending on the picture material. Attention: Should only be activated when outputting for tube TVs.
Correct TV borders
Black picture edges are added, this is worthwhile e.g. when playing on tube TVs.
Save generated video to
If you know that you want to burn the same video again, save the created video file. This will save you time the next time you burn.
don't burn, only create video
Select a location in the item above if you only want to create a video and not burn it (yet).
Click Next and then Create video to burn the DVD.
2 Burn DVD from file (optional)
Burn DVD from file
Burn DVD from file
If you have already created a video from your project and now want to burn it, select the from File option in the Video Wizard. Click Next.
Videodatei auswählen
Datei auswählen
Unter Dateiname klicken Sie auf das kleine Ordnersymbol. Wählen Sie hier eine Videodatei  aus, die Sie brennen möchten. Es muss sich dabei um eine Datei im MPEG- oder M2TS-Format handeln. Klicken Sie auf Weiter, um im nächsten Schritt den Brennvorgang zu starten.
